3D rendering as art
The most interesting thing in the rendering process is the selection of the atmosphere and perspective for the interior. As a rule at the beginning of work the visualizer as an artist presents a sketch of his future work. The lighting can be in the evening when the light is less intense and the colors are more subdued or it can be rendered in a brightly lit southern room when the colors seem to be richer and more saturated.
Well-chosen light is one third of the success of the shot.
You can play not only with natural light but also with artificial light sources. Whether the bedside table will illuminate with warm white neutral white or even cold depends on your idea and desire. Any option can be customized in 3Ds Max.
The right angles are another secret to effective visualizations.
It is important to maintain vertical lines as the slightest tilt can lead to an inharmonious frame.
When staged the renderer adjusts the focal length of each image.
The shorter the focal length the more it fits into the frame and vice versa.
Interior decor plays an equally important role in obtaining atmospheric visualizations. Depending on the room you can either add objects for the entourage or vice versa put things in order by removing all unnecessary things.
Do not forget to add close-ups (close-ups) of objects to further show the atmosphere of the interior
3D visualization as art The most interesting thing in the rendering process is under
